Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
Tank Sealer Supplemental Information and FAQs
Tank Sealer Information and FAQs
After the RustBlast step during the Tank Sealer Kit Process, I see surface rust inside the tank. Is that normal?
Some surface rust is to be expected after the RustBlast Step during the Tank Sealer Process.
SHOW MORE
Show More
Can I coat my Plastic or Polyethelyne Gas Tank with your Tank Sealer?
The KBS Tank Sealer System can be used on rigid plastic tanks to seal up the tank.
SHOW MORE
Show More
Can I just use the Tank Sealer and skip the KBS Klean and RustBlast?
The KBS Tank Sealer System is designed to use KBS Klean, RustBlast, and then seal the tank with Tank Sealer.
SHOW MORE
Show More
Can I reuse the KBS Klean solution when cleaning the tank?
The cleaning agent, KBS Klean, in the Tank Sealer System from KBS Coatings can be used several times to clean out the inside of a tank.
SHOW MORE
Show More
Can I use the KBS Tank Sealer System on a bio-diesel fuel tank?
The KBS Tank Sealer System is designed to prep and seal up bio-diesel and diesel tanks.
SHOW MORE
Show More
Can I use the Tank Sealer on a new tank?
KBS Coatings Tank Sealer System is designed to be used on new tanks to prevent them from rusting on down the road.
SHOW MORE
Show More
Can the Tank Sealer System be used on an air compressor tank?
The KBS Tank Sealing System is ideal to prep and seal up air compressor tanks preventing rust and leaks from forming.
SHOW MORE
Show More
Can the Tank Sealer System be used on oil tanks?
The KBS Tank Sealer System is ideal for prepping and sealing oil tanks to prevent them from rusting and leaking.
SHOW MORE
Show More
If I have a previous coating in my tank, should I remove it first before sealing up the tank with your tank sealing system?
KBS Coatings offers a Tank Stripper to strip out the old tank liners before prepping and sealing the tank with KBS Tank Sealer System.
SHOW MORE
Show More
Once you open the Tank Sealer do you have to use it right away or can I split between multiple tanks?
The Tank Sealer Kits from KBS Coatings can be used on mutliple kits if you have many multiple tanks to prep and seal.
SHOW MORE
Show More
What is the mesh in a Tank Sealer KIt?
The BackBone Mesh that can be included in the KBS Tank Sealer Kits is designed to strengthen any weak areas of the tank.
SHOW MORE
Show More
What is the minimum temperature to use the KBS 3 Step Tank Sealer System?
It is always best to do all three steps (KBS Klean, RustBlast, Tank Sealer) when the ambient and surface temperature are above 55F degrees.
SHOW MORE
Show More
When cleaning my tank, do I mix KBS Klean 10 to 1 with hot water or 1 to 1?
KBS Klean is a powerful cleaning concentrate and can be diluted 10-parts hot water to 1-part KBS Klean for most cleaning applications, but it is BEST to use KBS Klean full strength.
SHOW MORE
Show More
Why are there black streaks in Tank Sealer as I stir it?
The streaks are a visual side effect of the same pigment technology that makes Tank Sealer so effective as a fuel-resistant barrier. Here is exactly what is happening inside the can.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
