Can the KBS Tank Sealer System be used on an air compressor tank?
Yes, prepping and sealing air compressor tanks is a very popular application for the KBS Tank Sealer System .
Over time, air compressor tanks commonly develop internal rust due to condensation buildup. This rust can eventually lead to leaks or tank failure. By properly prepping and sealing the inside of the tank, you can prevent future corrosion and extend the usable life of the compressor tank.
If an air compressor tank already has a small pinhole leak (approximately the size of a pin tip), the KBS Tank Sealer System can seal the pinhole and help prevent it from spreading or worsening.
