Can I reuse KBS Klean solution when cleaning a tank?
Yes. After draining the used KBS Klean solution into a bucket, you can keep it for reuse until you have inspected the inside of the tank to ensure it has been cleaned thoroughly.
You can filter the KBS Klean solution as it drains to remove rust and debris, allowing you to reuse it for additional cleaning cycles.
Some customers have reused the solution multiple times—up to ten times—depending on how contaminated the tank is when you start.
Tip: Adding nuts, bolts, or loose chains inside the tank and frequently shaking and rotating the tank with the KBS Klean solution will help remove loose rust and debris more effectively.
