Can the KBS Tank Sealer System be used on oil tanks?
Yes, the KBS Tank Sealer System is commonly used to prep and seal oil tanks.
Tip: Proper surface preparation is especially important when sealing oil tanks. Any oil residue remaining inside the tank can interfere with adhesion and cause long-term performance issues if not completely removed.
