Why Are There Black Streaks in Tank Sealer as I Stir It?
If you've just cracked open a can of KBS Tank Sealer and started stirring, you may have noticed something alarming: dark or black streaks swirling through what should be a bright silver coating. Before you assume something went wrong in shipping or that your sealer is contaminated — take a breath. This is completely normal, and it actually tells you something important about why Tank Sealer works as well as it does.
The streaks are a visual side effect of the same pigment technology that makes Tank Sealer so effective as a fuel-resistant barrier. Here is exactly what is happening inside the can.
The Science: Leafing Aluminum Pigments
Most paint pigments are tiny spheres — essentially microscopic balls of color. Tank Sealer uses a different kind of pigment: aluminum flakes. These flakes are razor-thin, roughly hexagonal in shape, and much larger in diameter relative to their thickness. Think of them less like a grain of sand and more like a tiny coin.
To make these flakes perform properly, they are coated with fatty acids (such as stearic acid). This coating causes the flakes to float toward the surface of the liquid and orient themselves flat — lying face-up and overlapping each other like shingles on a roof. This self-orienting behavior is called leafing, and it is entirely by design.
Why leafing matters for your fuel tank: When the aluminum flakes lie flat and overlapping inside the cured sealer film, they create a physical labyrinth that fuel, ethanol, and corrosive vapors must navigate to reach the metal beneath. A sealer with leafing pigments provides a tighter, more durable barrier than one using standard round pigments. It is a feature, not a flaw.
Why Does It Look Black?
The "black" color is a trick of light — there is no black pigment in Tank Sealer. When the flakes lie flat at rest, the broad face of each flake acts like a tiny mirror, bouncing light directly back toward your eye and producing the bright, metallic silver color you expect to see.
When you stir, the mechanical turbulence flips and tumbles the flakes, standing many of them on their edges or orienting them at steep angles. They are now presenting their narrow edge — not their broad, reflective face — toward the light source. An edge-on flake absorbs and scatters light rather than reflecting it back at a direct angle. To the human eye, a surface that is not returning light appears dark or black — even when no dark pigment is present. The streak you see is simply the absence of direct reflection, nothing more.
What You Should Do
Stir gently. Vigorous agitation increases turbulence, which tips more flakes on edge and deepens the dark appearance. A slow, deliberate stir is all that is needed to recombine any settled solids. As the liquid settles after stirring, the flakes naturally return to their flat, leafing orientation and the silver color comes back.
Once Tank Sealer is applied and cures, the flakes lock into their flat, overlapping orientation permanently — giving you that strong, shingle-like barrier inside your tank. The dark streaks will not appear in the cured film.
Bottom line: Black streaks during stirring are normal and expected. They are a sign of the leafing aluminum pigments doing exactly what they are supposed to do. Your Tank Sealer is not dirty, degraded, or defective.
The black streaks are caused by a phenomenon called leafing — a deliberate feature of the aluminum flake pigments used in Tank Sealer. When the flakes lie flat and parallel, they reflect light directly back and appear bright silver. When you stir, the mechanical turbulence stands the flakes on their edges. Instead of reflecting light, the edges absorb and scatter it — and to the human eye, a surface not returning light looks dark or black.
There is no black pigment in Tank Sealer. Stir gently and the color will normalize once the sealer settles. See the full explanation above.
No. The black streaks are a normal, expected visual effect caused by the aluminum flake pigments being disturbed during stirring — not contamination, degradation, or a manufacturing defect. Once the sealer settles, the silver color returns. Your product is fine to use.
No. Once Tank Sealer is applied and cures, the aluminum flakes lock into their flat, overlapping orientation permanently. The cured film will appear silver. The black streaking only occurs when the flakes are disturbed by stirring and will not affect the appearance or performance of the finished coating.
Leafing is the tendency of aluminum flake pigments to float toward the surface of a liquid and orient themselves flat — overlapping like shingles on a roof. KBS uses leafing pigments in Tank Sealer because this orientation creates a tighter physical barrier inside the cured film. Fuel, ethanol, and corrosive vapors must navigate a dense, overlapping labyrinth of flakes to reach the metal beneath. It is a deliberate performance feature, not just a cosmetic choice.
Stir gently. Vigorous agitation creates more turbulence, tips more flakes on edge, and deepens the dark streaking. A slow, deliberate stir is all that is needed to recombine any settled solids. After stirring, allow the sealer to settle briefly and the silver color will return as the flakes re-orient flat.
Yes, absolutely. The black streaks have no effect on the product's performance or adhesion. They are a visual artifact of the leafing pigments being disturbed during stirring. Stir gently, apply the sealer as directed, and the cured coating will perform exactly as intended.
