Answers to common XTC Xtreme Temperature Coating questions: colors, XTC Primer, curing, exhausts, mufflers and furnaces. Type below to search, or browse the full list.
XTC Questions and Answers
What Colors Does XTC Come In?
Ten colors plus Clear, and a Matte Grey zinc rich primer. Most are matte.
Can XTC Be Used on a Motorcycle Exhaust?
Yes. 1 to 2 coats of XTC Primer, 1 to 2 coats of XTC, thin, then the engine heat cure.
Can I Leave XTC Primer as the Finish Coat?
Yes. It is 100% UV stable; topcoat only for a color other than matte grey.
Does XTC Primer Have to Be Heat Cured Before XTC Is Applied?
No. Apply both, then heat cure once at the end.
Can I Wrap Exhaust Headers After Coating Them With XTC?
Yes, once XTC Primer and XTC are fully heat cured.
Can XTC Be Used on a Muffler With Light Rust?
Yes, after removing the rust and priming with XTC Primer.
How to Heat Cure XTC on a Furnace Exterior
Fire the furnace: 350 degrees F surface for 20 to 50 minutes, ramping up and down slowly.
Painting an engine block? Compare XTC with Motor Coater on the engine and exhaust paints page, or contact us here with any XTC question.
