Answers to common KBS Strip questions: removing undercoating and powder coat, and whether it is safe on plastic. Type below to search, or browse the full list.
KBS Strip Questions and Answers
Will KBS Strip Remove the Undercoating on My Car?
Yes. Be patient, keep it warm up to about 80 degrees F, and plan on more than one application.
Will KBS Strip Remove Powder Coat?
Yes, cured powder coat comes off with no oven or blasting. Work as close to 80 degrees F as possible.
Can KBS Strip Be Used on Plastic Bumper Covers?
Not recommended: it can damage plastic. If you must, test first and use short, repeated applications.
Stripping a gas tank? The KBS Strip directions cover tank stripping step by step, or contact us here with any KBS Strip question.
