What Is the Frame Coater Kit in Satin Black?
The Frame Coater Kit in Satin Black is a satin black frame paint kit: KBS Coatings' complete 3-step rust prevention system pre-selected in RustSeal Satin Black, a 65 to 75 percent sheen finish, so no color choice is needed at checkout. The kit includes KBS Klean, RustBlast, and RustSeal, a moisture-cured coating that chemically bonds to bare or lightly rusted metal and cures to a 600°F heat-resistant film without cracking, chipping, or peeling.
65 to 75%
Satin Black Sheen
50 sq. ft.
Coverage per Kit
This page is the same $72 Frame Coater Kit sold on the standard Frame Coater Kit page, with RustSeal Satin Black pre-selected instead of left as an open color choice. The kit still includes a quart each of KBS Klean, RustBlast, and RustSeal in Satin Black, plus nitrile gloves, brushes, a stir stick, and a detailed step-by-step guide, enough to clean, prep, and apply two full coats across a full-size frame.
RustSeal is moisture-cured, so it is made stronger, not weaker, by continued exposure to humidity, the condition that causes most other coatings to fail. It also resists acids, alkalis, salts, solvents, oils, fertilizers, and refined petroleum products, which makes the kit suitable for automotive, marine, industrial, and household metal.
RustSeal is applied directly over tightly rusted or sandblasted metal, so full rust removal is never required. Satisfaction guaranteed!
Sam Memmolo Shows How to Use RustSeal and Cavity Coater
The Satin Black Frame Coater Kit is identical to the standard Frame Coater Kit in contents and price, at $72, except the RustSeal color is pre-selected to Satin Black instead of left as an open choice among 11 colors. Choose this page when Satin Black is already decided; choose the standard Frame Coater Kit page to compare all 11 RustSeal colors before ordering.
- Same kit, one less step: KBS Klean, RustBlast, and RustSeal Satin Black, plus gloves, brushes, and a stir stick, with the color decision already made.
- Same price: $72 for the full 3-step system, matching the standard Frame Coater Kit.
- Satin Black sheen: RustSeal Satin Black cures to a 65 to 75 percent gloss level, a mid-sheen finish between flat and gloss.
- Same coverage and cure chemistry: 50 square feet per kit with 2 coats, 600°F heat resistance once cured, identical to every other RustSeal color.
RustSeal Satin Black cures to a 65 to 75 percent gloss level, a mid-sheen finish that sits between RustSeal's flat Galvanized option (about 30 percent) and its Gloss Black option (85 to 95 percent). RustSeal itself is a finished, non-porous coating rather than a base layer that still needs a topcoat, bonding directly to bare or lightly rusted metal and curing to a 7H-hard film rated to 600°F.
- Surface Tolerant: Applies directly over treated rust and bare metal without full media blasting.
- 1K Formula: Ready-to-use single component with no hardener to mix.
- Moisture Cured: Strengthens with exposure to humidity instead of degrading.
- Deep Penetration: Bonds to bare metal, galvanized steel, and other substrates.
- Non-Porous: Forms a permanent barrier against moisture and oxygen once cured.
- Chemical Resistant: Repels fuels, oils, acids, and alkalis.
- High Heat: Withstands continuous temperatures up to 600°F (315°C).
- Flexible: Will not crack, flake, or peel under expansion and contraction.
- Long Shelf Life: 2+ years unopened; 6 months once opened, stored cool and dry.
Is RustSeal Satin Black a Good Black Frame Paint for Trucks and Trailers?
RustSeal Satin Black works as a black frame paint on truck, car, and trailer frames because RustSeal bonds directly to tightly rusted or sandblasted steel and cures to a non-porous film rated to 600°F. Two coats from one kit cover about 50 square feet, a full-size frame. RustSeal's rust protection holds up in sunlight, but its color and sheen fade under UV, so topcoat any part of the frame that sits in direct sun with BlackTop.
The Frame Coater Kit is built for full-size car and truck frames, but RustSeal's chemical resistance and moisture-cure make it suitable across automotive, marine, industrial, and household metal surfaces. Any bare or lightly rusted steel, galvanized metal, or fiberglass surface up to 50 square feet is a fit for one kit.
- Automotive
- Frames, chassis, floor pans, wheel wells, fenders, trunks, firewalls, engines, suspension parts, axles, roof drains, leaf springs, coil springs, and doors, almost every part on a car except the exhaust.
- Engine rooms, hulls, masts, bilges, heat exchangers, decks, chain lockers, pumps, fuel tanks, and boat trailers.
- Industrial
- Heavy transport equipment, steam pipes, concrete sealing, air conditioning repair, fiberglass repair, re-bar coating, steel roofing, and fuel or waste-water treatment tanks.
- Household
- Steam radiators, hand rails, support beams, lawn equipment, garage floors, pipes, appliances, and lead-based paint encapsulation.
One Frame Coater Kit covers a full-size car or truck frame, or roughly 50 square feet, with two coats of RustSeal Satin Black at 2 mils each. Expect up to 50 percent less coverage on bare wood, rough, or sandblasted surfaces, since porous surfaces absorb more material per coat.
| Coverage Basis | Typical Result |
| Standard 2-Coat Application | 50 sq. ft. (one full-size frame) |
| Porous / Sandblasted Surfaces | Up to 50% less coverage |
Recoat window: Apply the second coat 2 to 6 hours after the first, once it is dry to the touch and leaves no fingerprint.
Pro Tip: Doing more than just the frame? The Large Frame Coater Kit covers a larger area from a single order, also available with RustSeal color choice.
Satin Black RustSeal differs from Gloss Black RustSeal mainly in sheen: Satin Black cures to a 65 to 75 percent gloss level for a subdued, factory-chassis look, while Gloss Black cures to 85 to 95 percent for a brighter, wet-look shine. Both share identical cure chemistry, coverage, and 600°F heat resistance.
| | RustSeal Satin Black | RustSeal Gloss Black |
| Sheen level | 65 to 75% gloss | 85-95% gloss |
| Typical look | Subdued, factory-style finish | Bright, wet-look shine |
| Cure chemistry | 1K moisture-cured, identical to Gloss Black | 1K moisture-cured, identical to Satin Black |
| Heat resistance | Up to 600°F once cured | Up to 600°F once cured |
| Coverage per kit | 50 sq. ft. with 2 coats | 50 sq. ft. with 2 coats |
Gloss Black is the better choice for show vehicles or anyone wanting maximum shine on a visible frame; Satin Black is the more common pick for a factory-correct or work-truck appearance that hides light surface dust between washes.
RustSeal, including Satin Black, is not intended as a final UV finish on surfaces exposed to direct sunlight. In areas out of direct UV, like the underside of a frame, RustSeal serves as both the seal and the finish.
- Step 1 - RustSeal Satin Black (included)
- Seals rust and forms the base protective coating at a 65 to 75% sheen.
- Step 2 - Topcoat (optional, for UV-exposed areas)
- BlackTop, KBS Top Coater, or KBS MAXX protect RustSeal's color and sheen from UV fading.
Shop the All-In-One Chassis Kit
How to Stop Rust and Prevent Rust
A comprehensive guide to identifying and stopping corrosion permanently.
Durability & Flexibility Demo
Watch RustSeal withstand extreme stress without cracking or peeling.
Watch Video →
Which KBS Product Stops Rust Where
A quick guide to which KBS coating fits which car surface.
Watch Video →
Restore a Rusty Trailer Door
See the 3-Step System and Cavity Coater used together on a real repair.
Watch Video →
RustSeal Color Selection Guide
Compare sheen levels across all 11 RustSeal colors before you order.
RustSeal Application Directions
Full step-by-step directions, technical data, and safety notes.
Have questions before you buy? Find answers to the most common Satin Black Frame Coater Kit questions below, or
order it now and get it shipped same day.
The Frame Coater Kit in Satin Black is KBS Coatings' complete 3-step rust prevention system pre-selected in RustSeal Satin Black, a 65 to 75 percent sheen finish. It includes KBS Klean, RustBlast, and RustSeal, and covers a full-size car or truck frame, or any 50 square foot area, with two coats.
Same kit, same $72 price, same contents. The standard Frame Coater Kit page lets you choose from 11 RustSeal colors at checkout; this page skips that step and ships Satin Black automatically. Use this page when the color decision is already made.
RustSeal Satin Black cures to a 65 to 75 percent gloss level, between RustSeal's flat Galvanized option (about 30 percent) and its Gloss Black option (85 to 95 percent). It reads as a subdued, factory-style finish rather than a bright shine.
Yes. RustSeal is formulated for rusted metal, so tightly bonded or sandblasted rust does not need to be removed before coating, only loose scale, dirt, and oil. RustBlast in Step 2 etches and neutralizes remaining surface rust before RustSeal Satin Black seals it permanently.
Recoat within 2 to 6 hours, once the previous coat is dry to the touch and leaves no fingerprint. If more than 8 hours pass, wait 24 hours and lightly scuff the cured coat with a 320 grit pad before recoating.
No. RustSeal, including Satin Black, is not UV-stable and is not intended as a final finish in direct sunlight. Repeated UV exposure will cosmetically alter its color and sheen over time, though its rust protection does not degrade. For sun-exposed areas, topcoat with BlackTop, KBS Top Coater, or KBS MAXX for permanent UV protection.
One kit covers a full-size car or truck frame, or roughly 50 square feet with two coats. Expect up to 50 percent less coverage on bare wood, rough, or sandblasted surfaces since they absorb more material per coat.
Apply RustSeal Satin Black between 55 and 82 degrees F (13 to 28 degrees C). Higher humidity shortens cure time and lower humidity lengthens it, since RustSeal cures by absorbing moisture from the air rather than by evaporation.
Clean brushes and spray equipment immediately with KBS #1 Thinner or lacquer thinner. RustSeal must be cleaned up before it dries; once cured, it cannot be removed by any solvent. If it contacts skin, remove immediately with thinner followed by soap and water.
Topcoat with BlackTop, KBS Top Coater, or KBS MAXX once the final RustSeal coat is dry to the touch, typically 3 to 6 hours later. If the surface will stay out of direct sunlight, such as the underside of a frame, RustSeal Satin Black alone is the finish and no further step is needed.
