Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
KBS Klean Information and FAQs
After mixing your KBS Klean in warm or hot water and putting in spray bottle, can you store the KBS Klean mix and reuse without being warm?
KBS Klean mixed in a spray bottle can be kept and used when you need a powerful cleaner and degreaser.
SHOW MORE
Show More
Can I use KBS Klean full strength or is KBS Klean always supposed to be diluted?
KBS Klean is designed to be diluted as least one to one to be full-strength.
SHOW MORE
Show More
Can I use your KBS Klean in our parts washer?
KBS Klean is a concentrated cleaner and degreaser that works incredibly well as a detergent in a part washer.
SHOW MORE
Show More
Can KBS Klean Be Used As a Brake Cleaner?
Yes, KBS Klean is a concentrated, industrial-strength, water-based cleaner formulated to break down heavy automotive contaminants without relying on harsh solvents making KBS Klean the ideal brake cleaner.
SHOW MORE
Show More
Can we use this on our canvas boat cover to remove mold?
KBS Klean is very effective in cleaning canvas surfaces including boat covers that have mold on them.
SHOW MORE
Show More
Did Not Dilute KBS Klean With Water. What Should I Do?
KBS Klean is a concentrate and should be diluted with water at least one to one, but if that is not done, you can rinse the surface extremely well with water.
SHOW MORE
Show More
Do I need to protect my windshield from getting KBS Klean on it? I am planning to re-paint the top of my truck?
KBS Klean is used to clean windshields because KBS Klean will easily cut through bug guts and the like.
SHOW MORE
Show More
Does your KBS Kleen clean and neutralize salt residue?
KBS Klean is highly effective at cleaning and neutralizing harmful salt residue.
SHOW MORE
Show More
Is KBS Klean suitable for use prior to spraying automotive paint?
KBS Klean is an ideal cleaner to clean a surface before applying an automotive paint. KBS Klean does not leave a residue like solvent based cleaners.
SHOW MORE
Show More
My tank has an internal parts consisting of a mix of plastic and metal parts. Is it safe to use KBS Klean on these parts?
KBS Klean is a great cleaner for metal and plastic parts and works to clean the inside of a tank.
SHOW MORE
Show More
New metal straight from the factory so it's clean. Do I still need to use the KBS Klean?
KBS Klean is an ideal cleaner for new metals that tend to have manufacturing residues which can hinder paint adhesion.
SHOW MORE
Show More
Will KBS Klean harm a painted surface?
KBS Klean is an excellent cleaner for fully cured painted surfaces.
SHOW MORE
Show More
Will KBS Klean work on unpainted aluminum?
KBS Klean works really well to clean aluminum surfaces whether it is just to clean them or to get the surface ready for paint.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
