Why KBS Klean Is Used as a Brake Cleaner
Proper surface cleaning is the critical of any successful brake service or coating application. Oils, grease, brake fluid, and road contaminants left behind can compromise braking performance and prevent coatings from bonding correctly.
For this reason, KBS Klean is widely used as a powerful water-based brake cleaner and degreaser.
Before any brake service or coating application, surfaces must be completely free of contaminants. Even trace amounts of oil or residue can interfere with performance and durability.
KBS Klean is designed to:
  • Remove grease, oil, and brake fluid
  • Lift brake dust and road grime
  • Clean metal thoroughly prior to coating
  • Prepare surfaces for maximum adhesion
Proper cleaning is essential whether servicing brake components or preparing metal for long-term corrosion protection.
Industrial-Strength Water-Based Cleaning Power
KBS Klean is a concentrated, industrial-strength, water-based cleaner formulated to break down heavy automotive contaminants without relying on harsh solvents.
Its deep-cleaning performance makes it an excellent choice for brake cleaning applications where thorough contaminant removal is required.
Ideal for Brake Service Applications
Brake systems are routinely exposed to petroleum-based grease, brake fluid residue, and road contamination. These materials must be completely removed to ensure proper braking function and safe reassembly.
When used as directed, KBS Klean penetrates and lifts embedded contaminants, allowing them to be rinsed away cleanly and leaving metal surfaces properly prepared for continued service or coating.
KBS Klean: https://www.kbs-coatings.com/kbs-klean
KBS Klean Application Directions: https://www.kbs-coatings.com/kbs-klean-directions
