Why is KBS Klean Leaving a Residue on My Surface?
KBS Klean is a powerful concentrated cleaner and must always be diluted with water — warm or hot water works best — at a minimum ratio of 1 part KBS Klean to 1 part water for maximum effectiveness. Using it undiluted or at too strong a concentration is the most common cause of residue.
To remedy residue already on the surface, dampen a green Scotch-Brite style pad with clean water and gently scrub the affected area to rinse away any remaining cleaner.
Tip: Always rinse the surface thoroughly with clean water after using KBS Klean. Any cleaner left on the surface can interfere with adhesion of the next coating step.
KBS Klean Product Page: https://www.kbs-coatings.com/kbs-klean
KBS Klean Application Directions: https://www.kbs-coatings.com/kbs-klean-directions
