Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
BlackTop Information and FAQs
Can BlackTop Aerosol be applied directly to aluminum?
BlackTop Aerosol adheres incredibly well to aluminum surfaces providing a beautiful and durable finish.
SHOW MORE
Show More
Can BlackTop be applied over epoxy primer or polyester filler primer?
BlackTop is an ideal top coat for coating a surface that has been primed or has body filler on the surface.
SHOW MORE
Show More
Can BlackTop be used on wood?
BlackTop is easily used to coat wood to provide a UV stable, durable, and great looking finish.
SHOW MORE
Show More
Can I brush on the BlackTop paint or does it have to be sprayed?
BlackTop is formulated to be brush on, rolled or, or sprayed on and it looks like a powder coated finish when it is cured.
SHOW MORE
Show More
Can I mix different sheens (Gloss, Satin, Flat) of BlackTop to get my desired gloss level?
You can mix different sheens of BlackTop to create custom sheen that matches the sheen that you desire for your project.
SHOW MORE
Show More
Can I see an actual sample of the different sheens of BlackTop?
KBS Coatings provides actual painted out color samples so customers can determine which sheen of BlackTop they desire before purchasing.
SHOW MORE
Show More
How much BlackTop do I need to cover the frame and underneath components of a full-size pickup truck?
BlackTop is the ideal frame paint to coat the frame and underneath components of a full-size truck.
SHOW MORE
Show More
Is BlackTop urethane based?
BlackTop (non-aerosol) is a moisture cured urethane which is an advanced coatings technology which makes BlackTop extremely durable, yet flexible, and BlackTop offers excellent adhesion to prepared surfaces. +Read More.
SHOW MORE
Show More
Is the aerosol version of BlackTop the same as the standard (non-aerosol) BlackTop version?
BlackTop and BlackTop Aerosol are both incredible 1K and single stage coatings.
SHOW MORE
Show More
What is the shelf life of BlackTop?
BlackTop should be good for at least two years unopened and if opened and stored correctly, BlackTop should be good for at least six months after you open for the first time.
SHOW MORE
Show More
What should I use for cleanup when using BlackTop?
For cleaning up BlackTop, please use KBS #1 Thinner or lacquer thinner.
SHOW MORE
Show More
What type of a brush should be used to brush BlackTop for a smooth finish?
BlackTop is a durable, 1K paint that brushes on beautifully to protect frames and a chassis using a poly bristle brush.
SHOW MORE
Show More
Why is BlackTop OEM Satin Black Glossier Than I Expected?
Tips for making sure matte sheens of BlackTop are applied correctly for a nice matte finish.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
