Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
Cavity Coater Information and FAQs
Can Cavity Coater be applied with an undercoating style schutz gun?
KBS Cavity Coater is typically applied with an autobody underseal style schutz gun like th Schutz Underseal Spray Gun & 48-inch 360-Degree Spray Wand.
SHOW MORE
Show More
Can I apply Cavity Coater into the back side of the fuse and relay panels to prevent moisture from causing corrosion in the connections?
Cavity Coater can be used to coat the back side of the fuse panel to prevent rust and to prevent corrosion.
SHOW MORE
Show More
Can I reuse the Cavity Wand or is the Cavity Wand a single use item?
The Cavity Wand from KBS Coatings can be used an indefinite amount of times as long as you clean out the Cavity Wand between each use.
SHOW MORE
Show More
Does Cavity Coater stop rust on internal cavities that already have rust?
Cavity Coater is ideal for coating internal rusty surfaces to stop the rust that is already there and prevent the rust from getting any worse.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
