If you've ever struggled to get a RustSeal can open, you're not alone — and there's a good reason for it. Unlike ordinary paint, RustSeal's primary resin is an adhesive. When the can is shipped, vibration and pressure can work small amounts of coating material into the seam between the lid and the can, causing the lid to bond more tightly than you'd expect. This is completely normal and not a sign of a defective can.
The good news is that opening it correctly takes just a little patience and the right tool. A paint can opener with a curved or “L”-shaped tip is strongly recommended — flat-head screwdrivers tend to warp the lid and can compromise the seal you'll need to reseal the can later. The key is to work gradually around the entire perimeter rather than prying from one spot. The questions below cover why this happens, how to do it right, and what to avoid.
Because most RustSeal is shipped, some coating material may work its way between the can and the lid during transit. This can make the lid more difficult to remove than ordinary paint. In addition, the primary resin in RustSeal is an adhesive, which can further contribute to the lid sealing tightly.
If your can has a plastic locking ring on the lid, remove it first. We strongly recommend using a paint can opener with a curved or “L”-shaped tip. Flat-head screwdrivers are not ideal, as they often warp the lid.
Using the paint can opener, gently lift one small section of the lid. Rotate the can approximately 10 degrees and repeat. Continue working your way around the can until the lid has been loosened once. Then repeat the process, lifting slightly more each time, until the lid releases.
Do not attempt to pry the lid off from a single location. This can warp the lid and damage the compression seal, potentially making future resealing difficult.
