Getting the temperature and humidity right before applying RustSeal is one of the most important steps in achieving a durable, professional finish. Applied in the wrong conditions, even the best surface prep can be undermined — solvents flash off too fast, adhesion suffers, or the coating cures unevenly.
The good news is that the parameters are straightforward. RustSeal performs best when the product, air, and surface temperatures are between 55°F and 82°F, with relative humidity between 30% and 80% RH. The FAQs below cover the most common questions about working within — and around — these conditions.
RustSeal has been thoroughly tested and should be applied when the product, air, and surface temperatures are between 55°F and 82°F. Relative humidity should be between 30% and 80% RH.
Surface temperature is often lower than the surrounding air temperature. Always verify that both the surface and air temperatures are within the recommended 55–82°F range before application — the air temp alone is not sufficient.
If temperatures are too high, the solvents in RustSeal evaporate too quickly. This can result in a less-than-ideal finish and possible adhesion issues. Always apply within the 55–82°F range.
Too low (below 30% RH): RustSeal may take significantly longer to cure, which can affect the final appearance.
Too high (above 80% RH): RustSeal may cure too quickly, potentially leading to finish defects and adhesion issues.
Staying within the 30–80% RH window gives the coating the time it needs to flow and bond properly.
If temperatures or humidity fluctuate, wait until conditions stabilize within range before applying. Always perform the actual application when both surface and air temperatures are between 55–82°F and humidity is between 30–80% RH.
If temperatures or humidity are on the low side, allow additional cure time beyond what is stated in the RustSeal Directions.
Yes. RustSeal can be shipped or stored in below-freezing temperatures with no effect on the product. Always allow RustSeal to return to between 55–82°F before application.
Have questions? Reach out to us — we're happy to help.
Shop RustSeal  View Application Directions
