DiamondFinish Clear Aerosol is very convenient and produces a professional looking finish. Because it takes quite a bit of solvent to thin down DiamondFinish Clear to get it in an aerosol can, it requires six coats of DiamondFinish Clear Aerosol to equal one coat of DiamondFinish Clear.
If you are looking for a great looking finish and the convenience of an aerosol, grab the DiamondFinish Clear Aerosol. If you need ultimate durability, grab the DiamondFinish Clear which can be brushed, sprayed, or rolled.
TIP: Both DiamondFinish Clear Aerosol and DiamondFinish Clear can be cut and polished as needed to produce a mirror-like finish. If you are applying the DiamondFinish Clear Aerosol, be sure to get 6-10 coats down to give you the film thickness to do your cut and polish.
Please check out the complete DiamondFinish Clear Application Directions before you begin your project.
