KBS Top Coater was designed to be brushed on. When you brush KBS Top Coater on, the brush marks disappear and look like powder coating.
TIP: When brushing KBS Top Coater, apply thin, covering coats and do not overwork the brush as this can cause KBS Top Coater to cure too quickly possibly leaving visible brush marks. It is always best to brush an area and move on immediately versus brushing an area over and over again. If you brush over an area over and over again, you force the solvents out and run the risk of the brush marks not flowing out as well they are designed to flow out.
KBS Top Coater Product Page → https://www.kbs-coatings.com/top-coater.html
Please be sure to read the KBS Top Coater Directions before you start your project.
