Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
Motor Coater Information and FAQs
Can I Make Motor Coater An Aerosol?
Not all colors of Motor Coater comes packaged as an aerosol can, but you can always easily convert Motor Coater to an aerosol application using the Preval Sprayer Kit.
SHOW MORE
Show More
Can Metallic Colors of Motor Coater Be Brushed?
An extremely popular brushing technique for brushing metallic coatings is to brush out the coating, let the coat cure for a few minutes, then lightly brush the surface again in one direction which will help float the metallic pigments to the surface.
SHOW MORE
Show More
Can Motor Coater be applied to brake calipers?
Motor Coater is an ideal paint for brake calipers which will make your calipers pop and stand out.
SHOW MORE
Show More
Do I need anything special on bare aluminum prior to using Motor Coater?
Motor Coater adheres very well to aluminum surfaces.
SHOW MORE
Show More
Do you need to primer, or use a prep coating on the surface before apply Motor Coater?
For best results, always clean the surface to be coated with Motor Coater with KBS Klean and etch the surface with RustBlast.
SHOW MORE
Show More
Does Motor Coater need to be heat cured or will it completely air cure after seven days?
Motor Coater is easily cured by the ambient air and does not have to be heat cured.
SHOW MORE
Show More
How can Motor Coater be applied to an oil pan? Prep required?
Motor Coater is ideal for coating an oil pan.
SHOW MORE
Show More
I will be coating my marine engine. How would you recommend I prepare this spot before applying the Motor Coater Engine Paint?
Motor Coater from KBS Coatings is used all of the time to coat marine engines.
SHOW MORE
Show More
Is Motor Coater glossy and shiny?
Motor Coater is a gloss and shiny finish that retains the gloss.
SHOW MORE
Show More
Is Motor Coater UV resistant?
Motor Coater is is UV stable and designed to be in the sunlight so you can keep the hood up on your car and show off the engine compartment.
SHOW MORE
Show More
Looking to brush Motor Coater and wanted to know what type of thinner is needed?
Motor Coater Engine is designed to be brushed on and thinning is not required, but you can use KBS #1 Thinner or Xylene to thin Motor Coater if desired.
SHOW MORE
Show More
To apply Motor Coater with a spray gun, do I reduce, how much, and with what?
Motor Coater is easily reduced or thinned to spray with a spray gun.
SHOW MORE
Show More
What is the maximum temperature Motor Coater can handle?
Motor Coater is good to 450F which is more than enough for water cooled engines, oil pans, transmissions, calipers, etc.
SHOW MORE
Show More
Will Motor Coater work on other car parts like spindle, upper A arms, etc.?
Motor Coater is an excellent automotive, exterior grade UV stable coating that adheres well to a variety of surfaces and provides a beautiful, durable finish.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
