For best results, always clean the surface to be coated with Motor Coater using KBS Klean, then etch the surface with RustBlast before applying your finish coat.
TIP:
For surfaces that are prone to rusting, pitted, or coarse in texture,
apply RustSeal Galvanized
as a base coat first — it smooths the surface and locks out rust
under your Motor Coater finish coat.
Ready to coat your engine or motor?
View full application directions, color options, and technical specs.
▶ Motor Coater Application DirectionsFrequently Asked Questions — Motor Coater Surface Preparation
Motor Coater is a self-priming, direct-to-metal finish coat — a separate primer is not required.
However, for maximum adhesion and durability, always clean the surface with
and etch it with RustBlast
before applying. On pitted, coarse, or rust-prone surfaces, a base coat of
RustSeal Galvanized
is strongly recommended for a smooth, long-lasting finish.
For surfaces that are pitted, coarse, or prone to rusting, apply
RustSeal Galvanized
as a base coat before Motor Coater. RustSeal encapsulates existing rust, smooths rough
surfaces, and forms a permanent barrier that prevents rust from forming under your finish coat.
Motor Coater will bond to clean, bare metal, but skipping the prep steps significantly
reduces adhesion and long-term durability — especially in high-heat engine environments.
For the best results, always follow the full KBS system:
clean with KBS Klean,
etch with RustBlast,
and (if needed) seal with RustSeal
before applying Motor Coater.
Follow the KBS 3-Step System in this order for best results:
- Step 1 — Clean: Apply KBS Klean to remove all grease, oil, and contaminants.
- Step 2 — Etch & Rust Proof: Apply RustBlast to etch bare metal and neutralize rust.
- Step 3 — Seal (if needed): For pitted or rusty surfaces, apply RustSeal Galvanized as a base coat.
- Step 4 — Finish Coat: Apply Motor Coater for a durable, high-heat finish.
Still have questions about preparing your surface for Motor Coater?
Our coating specialists are ready to help you get the best results on your project.
Contact KBS Coatings
