Motor Coater Engine Paint is designed to brush on smoothly, but it can also be converted into a professional-quality engine paint aerosol for easy spray application. Many Motor Coater colors are available pre-packaged in aerosol cans — and every color can be spray-applied using a simple thinning method with a Preval Sprayer Kit.
To create your own engine paint aerosol, reduce Motor Coater 30–40% with KBS #1 Thinner or xylene, then spray through a Preval Sprayer Kit. The result is the same smooth, durable, heat-resistant finish as a factory aerosol — in any Motor Coater color you choose.
This method is ideal for custom colors, small touch-ups, or when your preferred shade is not available in a ready-to-use spray can.
What You Need
Preval Sprayer Kit
Frequently Asked Questions — Motor Coater as Aerosol
Still have questions about Motor Coater or spray application?
Contact KBS Coatings Support Shop Motor Coater
