Motor Coater is heat resistant up to 450°F, which is more than enough for water-cooled engines, oil pans, transmissions, and calipers. Motor Coater does not burn off!
TIP: High-Heat Applications
If you need a coating for exhaust manifolds, headers, or any surface reaching 1200-1500°F, XTC is our superior high-temperature solution.
Get Professional Results
Ensure a show-quality finish by following our comprehensive, step-by-step guide.
VIEW MOTOR COATER APPLICATION DIRECTIONS →
