To spray Motor Coater, thin it 5–10% using only KBS #1 Thinner or Xylene — slow-evaporating solvents that allow proper flow-out for a smooth finish. Set your spray gun to 35–45 psi for siphon/pot guns, or 25–35 psi for gravity/top-feed guns.
Motor Coater Spray Gun Settings
| Gun Type | Recommended PSI | Metric (kPa) |
| Siphon / Pot Gun | 35–45 psi | 250–330 kPa |
| Gravity / Top-Feed Gun | 25–35 psi | 170–250 kPa |
Approved thinners: Use only KBS #1 Thinner or Xylene. These slower-evaporating solvents give Motor Coater the time it needs to level and flow out properly. Fast-evaporating solvents such as lacquer thinner or acetone will cause blushing, fisheye, and poor adhesion — do not substitute.
View full spray & application directions for Motor Coater —
including surface prep, coat counts, recoat windows, and cure times.
Motor Coater Full Application Guide →
Frequently Asked Questions — Spraying Motor Coater
A reduction of 5–10% is normally adequate. Measure by volume —
for example, add roughly 1 oz of thinner per 10–20 oz of Motor Coater.
Over-thinning reduces film build and durability, so stay within this range.
or Xylene. Both are slower-evaporating solvents specifically matched to Motor Coater's
chemistry, allowing the coating to level and flow out before the film sets.
Set a siphon or pot gun to 35–45 psi (250–330 kPa).
Start at the lower end and adjust up if you see orange-peel texture or
poor atomization. Higher pressure in siphon guns compensates for the
longer paint column lifting from the cup below.
Set a gravity or top-feed gun to 25–35 psi (170–250 kPa).
Gravity-feed guns require less pressure because paint feeds naturally from
the cup above. Staying in the lower range prevents over-atomization and
wasted material.
No. Fast-evaporating solvents like lacquer thinner, acetone, or
mineral spirits will cause the coating to dry before it can flow out, resulting
in blushing, fisheye, and compromised adhesion. Always use
or Xylene only.
Still have questions about spraying Motor Coater?
Our technical team is ready to help.
Contact KBS Technical Support
