Motor Coater is ideal for coating an oil pan. The application process follows our standard engine coating procedure, where the quality of your surface preparation determines the longevity of the finish.
TIP: The Professional Foundation
Oil pans are highly susceptible to road debris and moisture. We strongly recommend priming the prepped oil pan with RustSeal. This creates a permanent, rust-proof barrier before you apply the Motor Coater color coat.
Get Professional Results
Ensure a show-quality finish by following our comprehensive, step-by-step guide.
VIEW MOTOR COATER APPLICATION DIRECTIONS →
