Shop
How-To & Support
Reseller Finder
Login
Register
(0)
Call:
(219) 263-0073
Text Support:
(219) 531-7797
SHIPPING:
0
Items
Toggle navigation
Products
KBS Tank Sealer System
Stop Rust: Kit Finder
Large Frame Coater Kit
Frame Coater Kit
Ultimate Frame Coater Kit
Stop Rust Quart Kit
Stop Rust Gallon Kit
System Sampler Kit
Ultimate System Sampler Kit
Large System Sampler Kit
All-In-One System Sampler Kit
All-In-One Chassis Kit
All-In-One Kit
4 Quart Special
4PAK
MotorCycle Frame Coater Kit
KBS Rust Converter
Trunk & Floorpan Repair Kit
Auto Fuel Tank Sealer Kit
Cycle Tank Sealer PLUS Kit
25-50 Gallon Tank Sealer Kit
All Clear Coats
KBS Top Coater
KBS Top Coater 1K Aerosol
Clear Coat 1K Quart Kit
Clear Coat 1K Gallon Kit
Headlight Restore Kit
KBS Bed Renu
KBS Bed Liner
Engine Paints &
Motor Coater Kit
XTC Primer
Rotor Restoration Kit
Cavity Coater
Cavity Spray Wand
Paint & Tank Stripper
Fusion Self-Etch Primer
Putty, Fillers & Patches
KBS Premium Body Filler
NuMetal Epoxy Putty
KBS UV Light
Force Black Nitrile Gloves
Paint Spray Guns
Dry Air Spray Gun Filter
Pre-Val Spray Gun
UnderSeal Spray Gun & Probe
KBS Paint Spouts
KBS Paint Brushes
Rust Protection
Clearcoats/Topcoats
Engine & Exhaust
Technical Info
3-Step System Overview
3-Step Tank Sealing System
Flow Charts
Rust Prevention Flow Chart
Directions Sheets
RustSeal TDS/Directions
KBS Klean TDS/Directions
RustBlast TDS/Directions
Tank Sealer TDS/Directions
BlackTop TDS/Directions
KBS MAXX TDS/Directions
KBS MAXX Clear TDS/Directions
KBS Top Coater TDS/Directions
KBS Fusion TDS/Directions
Directions Sheets (cont.)
Motor Coater TDS/Directions
Cavity Coater TDS/Directions
KBS Strip TDS/Directions
KBS Bed Liner TDS/Directions
KBS Bed Renu TDS/Directions
KBS UnderCoat TDS/Directions
KBS Patch TDS/Directions
NuMetal TDS/Directions
BackBone TDS/Directions
Concrete Paint TDS/Directions
Tech Data Sheet
RustSeal Tech Data
Tank Sealer Tech Data
Chemical Resistance
SDS
Request SDS
KBS Support Desk
KBS Support Desk
KBS Support Forum
KBS Support Forum
Videos & How-To's
How-To's
RustSeal How-To
Tank Sealer How-To
Videos
RustSeal Videos
Tank Sealer Videos
NuMetal Videos
Guidelines
More
KBS Application Support
KBS Coatings Support Desk
KBS Coatings Success Forum
Sign Up Today
Request a Free Color Catalog
Request Color Sample
KBS Info
Request SDS
Account Info
Create An Account
Log Out
Canada Shipping
Canada Shipping
Customer Photos
KBS Coatings In Magazines
Reseller Login
Reseller Website Login
KBS Resellers
Reseller Ordering Login
Reseller Finder
DiamondFinish Clear Information and FAQs
Can DiamondFinish Clear be applied over another coating (like a base coat)?
DiamondFinish Clear can be applied over other coatings that are fully cured.
SHOW MORE
Show More
Can DiamondFinish Clear be applied over hydrographics?
DiamondFinish Clear is the ideal clear coat for clear coating over hydrographics.
SHOW MORE
Show More
Can DiamondFinish Clear be applied over rusted metal?
DiamondFinish is an ideal clear coat to apply over an older, rusty surface to keep the patina look and prevent future rust.
SHOW MORE
Show More
Can DiamondFinish Clear be applied wet on wet?
Learn the correct recoating process for DiamondFinish Clear — when to apply additional coats, how to use the fingerprint test, and what to avoid for a flawless, long-lasting finish.
SHOW MORE
Show More
Can DiamondFinish Clear be used as a concrete sealer or clear concrete paint?
DiamondFinsih Clear is an excellent concrete sealer that makes the concrete surface more durable and makes for much easier clean-up.
SHOW MORE
Show More
Can DiamondFinish Clear be used on industrial equipment as a protective clear coat?
DiamondFinish Clear is an ideal clear coat for industrial equipment.
SHOW MORE
Show More
Can DiamondFinish Clear be used over laquer and enamel paint?
DiamondFinish Clear can be applied over fully cured lacquer or enamel paints.
SHOW MORE
Show More
Can DiamondFinish Clear be used over RustSeal?
We do not recommend putting DiamondFinish Clear over RustSeal because although DiamondFinish Clear is absolutely UV stable, DiamondFinish Clear does not block the UV rays from getting through to the RustSeal.
SHOW MORE
Show More
Can DiamondFinish Clear be used over water based paint?
DiamondFinish Clear is an ideal clear coat to apply over fully cured water based coatings to provide protection and gloss.
SHOW MORE
Show More
Can I clear coat carbon fiber with DiamondFinish Clear?
DiamondFinish Clear is an ideal clear coat to clear coat carbon fiber to protect the surface with a durable finish.
SHOW MORE
Show More
Can I clear coat wood with DiamondFinish Clear?
DiamondFinish Clear is used to clear coat wood, both sealed and unsealed, raw wood to provide durability and gloss.
SHOW MORE
Show More
Can tints, pearls, and metal flake be added to DiamondFinish Clear?
Tinting and adding metal flake to DiamondFinish Clear is extremely common.
SHOW MORE
Show More
Can you use Diamondfinish Clear on 1986 fiberglass Bass boat top plate?
Wipe the fiberglass surface down with KBS Klean. Allow to dry. Then apply the DiamondFinish Clear.
SHOW MORE
Show More
Do the Brush Mark Really Flow Out When Brushing DiamondFinish Clear?
DiamondFinish Clear was designed to be brushed and when DiamondFinish Clear is brushed, the brush marks do flow out.
SHOW MORE
Show More
Do you recommend DiamondFinish Clear for direct to metal applications?
DiamondFinish Clear is specifically formulated for many applications including Direct To Metal Applications.
SHOW MORE
Show More
How can I matte down DiamondFinish Clear to give a satin of flat sheen?
You can matte down DiamondFinish Clear after 24 hours to give a nice matte or flat finish to your clear coat finish.
SHOW MORE
Show More
How do I speed up the curing of DiamondFinish Clear?
To get the humidity higher, wet the floor, wet some cardboard in the room, throw some wet towels on the floor, add a humidifier to the room or do whatever works for you and your situation.
SHOW MORE
Show More
My DiamondFinish Clear has thickened some. Can I thin it?
DiamondFinish Clear can be thinned and reduced down with KBS #1 Thinner when needed.
SHOW MORE
Show More
Should DiamondFinish Clear be thinned for spraying? With what do you thin DiamondFinish Clear?
For thinning DiamondFinish Clear, you need a slower evaporating solvent than a traditional paint thinner.
SHOW MORE
Show More
Storage Tips For DiamondFinish Clear When Dipping Lures
Clear coating fishing lures and crank baits by dipping is an extremely common application for DiamondFinish Clear. Over the past 20+ years, we have been given quite a few storage tips when using DiamondFinish Clear to dip fishing lures.
SHOW MORE
Show More
The paint is peeling off my hood on my car, could I lightly sand it and apply DiamondFinish Clear to these areas?
DiamondFinish Clear is ideal for stopping peeling paint and small rust spots on a vehicle.
SHOW MORE
Show More
There are small bubbles in my cured DiamondFinish Clear. How do I prevent this and fix it?
Small bubbles in the DiamondFinish Clear film are easy to correct and then achieve a beautiful and durable finish.
SHOW MORE
Show More
What is the best way to open my can of DiamondFinish Clear?
There is a proper way to open a can of DiamondFinish Clear so you are able to close the lid and save DiamondFinish Clear for future use.
SHOW MORE
Show More
What is the best way to store DiamondFinish Clear after you open the can?
DiamondFinish Clear can easily be stored for at least six months after opening.
SHOW MORE
Show More
Dispense a working amount of DiamondFinish Clear into a separate container (steel or glass is best) and seal original can immediately.
SHOW MORE
Show More
What is the coverage for DiamondFinish Clear?
For DiamondFinish Clear, theoretical coverage at one mil (25 µm) is 400 sq.ft. per gallon/9.8 m² per liter.
SHOW MORE
Show More
What is the recommendation for wet sanding and buffing times on DiamondFinish Clear?
For a mirror-like finish, DiamondFinish Clear can be cut and polished or buffed as a normal automotive clear coat after 24 hours under normal conditions.
SHOW MORE
Show More
What kind of roller covers work best for DiamondFinish Clear?
You can roll on DiamondFinish Clear and the best roller cover to use is a low nap mohair roller cover.
SHOW MORE
Show More
Will DiamondFinish Clear adhere to a plastic like a hard hat? Also, will it go over vinyl stickers without harming them?
DiamondFinish Clear is ideal for clear coating hard plastics and also sealing up vinyl decals and vinyl stickers.
SHOW MORE
Show More
Will DiamondFinish Clear chip?
DiamondFinish Clear is formulated with advanced coatings technologies allowing DiamondFInish Clear to be virtually chip-proof under even extreme circumstances.
SHOW MORE
Show More
Shop All Products →
Shop by Category
Rust Protection
Clearcoats & Topcoats
Engine & Exhaust
Resources
Direction Pages
Videos & How-To’s
Info
Reseller Finder
