RustSeal Satin Black (and all matte sheens of RustSeal) are heavily pigmented. It is critically important to get all matting agents mixed back into suspension using a mechanical mixer attached to a drill (such as the KBS Hurricane Paint Mixer) or at minimum a paint stir stick. Effective mixing includes repeatedly touching the bottom of the can and lifting to fully disperse any settled pigments and/or matting agents. Skipping this step is the most common cause of an unintended gloss finish when using RustSeal Satin Black or any other matte sheen.
If RustSeal is not mixed thoroughly before each application — and occasionally during application — the finish may turn out glossier than desired. Re-stir the coating every 15–20 minutes during use to keep matting agents evenly distributed.
Be sure to apply RustSeal in thin coats only to achieve a proper matte finish. Applying medium or heavy coats can cause the finish to appear glossier than intended. Multiple thin coats also provide better rust prevention and adhesion than a single heavy coat.
If a flatter finish is desired, you may reduce RustSeal by up to 20% using KBS #1 Thinner or xylene to increase matting. Reducing also improves flow and leveling, which can help achieve a more uniform matte surface on large or complex areas.
When first applied, RustSeal Satin Black may appear glossier than expected. However, it will matte down as it cures. Always allow a full 24-hour cure before evaluating the final sheen. Judging the sheen too early — especially in humid or cool conditions — can lead to unnecessary re-coating.
Shop RustSeal View Application Directions Shop Hurricane Paint Mixer Shop KBS #1 Thinner
RustSeal Satin Black – Frequently Asked Questions
RustSeal Satin Black and all matte sheens of RustSeal are heavily pigmented, with matting agents that settle to the bottom of the can during storage. Proper mixing is required to fully re-suspend those agents before application. If they remain settled, the coating will apply with too much gloss and will not achieve the intended matte or satin finish.
Use a mechanical mixer such as the KBS Hurricane Paint Mixer attached to a variable-speed drill for best results. The mixer should repeatedly contact the bottom of the can and lift upward to break up any settled solids. At minimum, use a paint stir stick and stir vigorously for several minutes before application. Continue to stir every 15–20 minutes during use.
If RustSeal Satin Black is not mixed thoroughly before and during application, the matting agents will be unevenly distributed throughout the coating. The result is a finish that appears glossier than intended — often noticeably so. In some cases the finish may look similar to a semi-gloss or even full gloss RustSeal rather than the expected satin or matte sheen. Thorough mixing before every application session is the single most important step for achieving a consistent matte finish with RustSeal.
RustSeal Satin Black should always be applied in thin coats only. Applying medium or heavy coats increases the wet film thickness, which traps matting agents beneath the surface and causes the finish to cure glossier than intended. Thin coats allow the matting agents to migrate to the surface properly as the coating cures, producing the correct sheen. Multiple thin coats also provide better rust prevention coverage and adhesion than a single thick coat. See the RustSeal Application Directions for full coat thickness and recoat time guidance.
Yes. RustSeal may be reduced by up to 20% using KBS #1 Thinner or xylene to help increase matting and achieve a flatter finish. Reducing lowers the viscosity of the coating, which allows matting agents to distribute more evenly during application and cure. This technique is especially useful when spraying RustSeal or when working in warm conditions where the coating flashes faster than desired. Do not exceed 20% reduction, as over-thinning can compromise the rust-preventive properties of the coating.
When first applied, RustSeal Satin Black may appear glossier than expected. This is normal — the matting agents in the wet coating have not yet fully migrated to the surface. As the coating cures and solvents evaporate, the surface flattens down to the correct satin or matte sheen. Always allow a full 24-hour cure at room temperature before evaluating the final finish. Assessing the sheen while the coating is still wet or partially cured — or in cold, damp conditions where curing is slowed — will give a false reading. If the finish still appears too glossy after a full cure, review your mixing and application technique.
